Hello ,
We can read the csv file from the thingworx csv extension. Is there a possibility to read the excel having multiple tabs by specifying the sheet name or something..? .
What is the best way to read excel with multiple tabs.
Thanks!!
DPM is the new Digital Performance Management solution PTC has released.
ThingWorx Applications is actually a set of apps RTPPM (Real Time Production Performance Management), AMU (Asset Monitoring and Utilization) and CWC (Connected Work Cell) also a solution PTC has released
It isn't in the manufacturing apps which you are referring to
It can be done with the proper java extension but I don't think one is officially available?
I think if you install something like ThingWorx Apps or DPM they have an extension included to read Excel files.
I think Manufacturing apps only does CSV not excel.
When you say thingworx app, is that "ThingWorx-Utilities-Core"/"ThingWorx-Utilities-Software-Content-Management" which is part of thingworx foundation..?
DPM stands for..??
Thanks for the response!!
Sorry!! i am not sure i am looking at right place for the download. Is it possible for you to send a link or the screen capture of the installable which you are talking about.
Thanks for all your support.
Hi @sbt.
My apologies. I discovered that DPM is available. It requires a paid subscription and is available for distribution through Solution Central.
--Sharon
Hello @sbt - Although it requires Excel Online (ie: Office 365 online version), ThingWorx Flow has a connector which allows triggering workflows off of and integrating through Excel files.
