I have the same problem with javascript/ajax request, if I use custom authenticator that handles redirection, changing the pages to something else works fine and user is redirected properly, but if user tries to use navigation menu or something similiar it fails with exact same error (pop up with HTML body of login page). Have You found any solution?
This solution is working fine in case the use tries to navigate to another page after timeout
but if the user tries to navigate using sub menu for example , I get a popup with the HTML code of the login page (check attached screenshot)
I think that's because switching submenu mashup happens using ajax/javascript , so redirection is sent back from authenticator but it is not handled by mashup, any solution in this case ?
I`m searching for resolution of this problem. Any news?
unfortunately nothing yet
