I'm trying to reference the current date when having a SQL query perform. I have my service setup as a SQL (Query) and I have the following code.
Select Result, Result_On from Tests where Var_Id = '20903' ORDER BY Result_On DESC
I'm looking to have the query only pull results where Result_On is equal to the current date (today's date), however I can't seem to figure out how to make the query reference the current date.
Any help would be greatly appreciated.
Hi Michael,
Depending on your database, there may be built-in date functions available. For example, MySQL has NOW(), CURDATE() and CURTIME(). Here's a reference for MySQL: http://www.w3schools.com/sql/sql_dates.asp
I would imagine most databases provide this functionality.
Adam
Thanks Adam for the help! I was able to find out in order to reference the current time in a SQL(query) service inside a thing you have to refer to it as CURRENT_TIMESTAMP.
