ReferenceError: "window" is not defined.
rmasoud1
I am not fairly familar with javascript, but found that I could use the following code to get the current URL of the open webpage.
var url = window.location.href;
I am getting an error, "window" is not defined, which I do not understand why.
Is it part of a library not in Thingworx and if so, how can I import that library into Thingworx?
Thank you,
Rami
posipova
20-Turquoise
(To:rmasoud1)
THe function is not part of the rhino javascript engine. You may look into developing a custom java extension that would utilize a similar function and then importing it into your ThingWorx instance.
1 REPLY 1
posipova
20-Turquoise
(To:rmasoud1)
