Regarding ThingWorx localhost installation
LJ_9962981
My ThingWorx localhost is failing the installation. I have an appropriate java version and an appropriate jdk version (1.8.0) in my computer. Still is failing. What could be the issue?
@LJ_9962981
Please confirm what is the error you are getting when the installation fails? What is Thingworx version you are trying to install?
The version I am trying to install is ThingWorxFoundationH2trial-9.1.0-x64
@LJ_9962981
Refer this article and check if all the environment variables are set correctly.
