Regarding pie chart, donut chart not showing ShowDonutSliceLabel property
AS_12144955
Hello Everyone,
I'm trying to create a donut chart by using the Pie chart. My requirement is to display the label in the center of that donut chart. I tried looking for the solution in help center which leads me to a property call ShowDonutSliceLabel, which I'm not able to see in my pie chart property.
No, it's not the version gap I feel because I m using the ver 9.4 and refer the same ver doc. If anyone knows how to enable it pls let me know it would be a great help.
Thanks in advance!
4 REPLIES 4
Hi @Surya_Tiwari Thanks for the reply, but I think it's the old ver solution. Now we have donut sizing available.
Hi @AS_12144955  Yes, now the ShowDonutSliceLabel property is available but it will work to define a radius to display the donut chart.
Or
You can configure the widget as a donut chart by specifying a value within the chart , such as the DonutHoleSize property. A donut chart is a pie chart without the center part. Optionally, you can use the center of the donut chart to display additional information about the selected data by enabling the widget ShowDonutSliceLabel property. Both the value and the label of the selected slice are displayed in the empty area in the center of the donut chart and the ValuesPosition property is ignored.
Hello @AS_12144955
It looks like you have some responses from a community member. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
