Remote Control Tutorial - entities.xml
gmachado
My thingworx composer can't import the file: Entities.xml
It says: Not acceptable
In the tutorial they open the version 7 but my version it's 8.
Best Regards
Gonçalo Machado
8 REPLIES 8
posipova
20-Turquoise
(To:gmachado)
Could you please open Monitoring -> ApplicationLog and see what error appears in there? Probably some dependency.
This:
[message: Import Failed: Validation Failure: ThingTemplate RemoteControl Had An Invalid Implemented Thing Shape : [Vuforia.VuforiaExperienceService.VuMarkEnabledShape]]
posipova
20-Turquoise
(To:gmachado)
Seems like it's missing the thingshape mentioned in the error. What happens if you manually create a thigshape with that name?
Keeps the same error.
[Thingshape: VuMarkEnabledShape]
posipova
20-Turquoise
(To:gmachado)
It is the same error in the ApplicationLog even with VuMarkEnabledShape ThingShape created? There might be other dependencies.
Sorry for the reply delay.
How can I see the dependencies that are missing? In the ApplicationLog I think that he keeps asking about the VuMarkEnabledShape.
I also have the same problem.
Trying to import the provided Entities.xml file from the TV Remote Control Tutorial, as described in the video:
https://www.youtube.com/watch?v=BXbPh7IuTqc&feature=youtu.be   (Time 49:10)
i get the following error:
