Remotely configuring a thingTemplate/thing via rest
jpytlowany
I noticed some ThingTemplates have a configuration section. Say, for example, the mail extension or mqtt extension.
I know you can create, enable, and start/stop things through rest, and even give them a template, however is there a way to remotely set these configuration settings. Perhaps via REST or another method.
For example, in the mail extension's configuration settings: Can you remotely set (i.e. from PC) the mail server address, user details etc.
Kind regards,
John
I realized my syntax was wrong. The problem is resolved. I can provide an example at a later time
John, you can create a Mashup for this as well. For example, if you take the MailServer Thing, you can use a service like GetConfigurationTable and bind that to a Grid. The tableName would be ConnectionInfo, and that would display all fields in the configuration section.
Hi, Thanks for the info.
So i have a javascript application try to call the service "SetConfigurationTableRows",
my input is:
var data = {
  "tableName":"Mail Server Connection Parameters",
  "values" : {
  "dataShape" : {
  "fieldDefinitions": {
  "SMTP Server":{
  "name":"SMTP Server"
  "rows":[{"SMTP Server":"localhost"}]
Im getting an error. (406, specifically).
Should it be something more like,
var data = {
  "values" : {
  "dataShape" : {
  "SMTP Server"}},
Im am using POST method.
John
