Remove the extra space of footer while collapsing
adityak506
7-Bedrock
Hi, In the footer of a mashup, I am using the collapse and expand property. In the footer, I have a tab responsive widget and their content. In this mashup, on click of button, I am expanding and collapsing the footer content. But when collapsing it is occupying some empty space, how to remove the empty space.
Aditya Kumar
1 ACCEPTED SOLUTION
It's fixed now by using transparent layout in a footer layout.
Aditya
7 REPLIES 7
Could you attach mashup and corresponding entities to take a look?
Thank you,
Raluca Edu
Aditya
slangley
23-Emerald II
(To:adityak506)
Hi @adityak506.
Glad you found a solution.  For the benefit of others on the community, please mark your last post as the Accepted Solution.
--Sharon
This would probably be more in the CSS section but anywho...
The problem is not with the sections themselves but actually with the heading and paragraph tags. The margins of them are extending beyond the height of the sections. Normalize.css sets the properties to be more consistent among browsers but a margin still applies. shareit app vidmate apk
Thanks Bhaiterabhai for the suggestion and reply!
Thanks Sharon for the reply!
Thanks Raluca for the reply!
