It's fixed now by using transparent layout in a footer layout.
Aditya
Could you attach mashup and corresponding entities to take a look?
Thank you,
Raluca Edu
Aditya
Hi @adityak506.
Glad you found a solution. For the benefit of others on the community, please mark your last post as the Accepted Solution.
Regards.
--Sharon
This would probably be more in the CSS section but anywho...
The problem is not with the sections themselves but actually with the heading and paragraph tags. The margins of them are extending beyond the height of the sections. Normalize.css sets the properties to be more consistent among browsers but a margin still applies. shareit app vidmate apk
