Repeater Child mashup not populating
TanmeyTWX
I'm passing an Infotable as "All Data" to a Repeater as well as Grid.
Grid is displaying all the required data but thats not happening with Repeater.
Seems Repeater Child-Mashup isn't populating but I checked every binding thrice , no luck.
Note: Same service being used to display both Grid(above) and Repeater(below). Service using a datashape to bind data and same datashape being used at the Child-Mashup side to bind indivdual coulmns to Child mashup.
8 REPLIES 8
Note: DataRowParameter (Mashup Parameter) used to pull-in inputs for Mashup
PaiChung
22-Sapphire I
(To:TanmeyTWX)
Did you map the necessary fields in the Repeater Widget to the Mashup parameters?
Yes. I did.
I have got 4 columns to display but getting one column on the repeater itself.
3 Label columns and One Textbox column...is there but getting textbox cloumn only.
PaiChung
22-Sapphire I
(To:TanmeyTWX)
How did you map the Mashup parameters in your Mashup that you are displaying in the repeater?
Also can you show us the Repeater Property configuration?
Child(base mashup):
Repeater Mashup:
same service giving output to Grid but when trying to bind service to Repeater,displaying only one column.
PaiChung
22-Sapphire I
(To:TanmeyTWX)
I see something strange in your wiring.
In your Mashup it seems to think DataRowParameter is a boolean?
Can you check that and make that an InfoTable and assign the DataShape
If it is already an InfoTable, then I would delete the Parameter and re-create it and see if it shows in the dropdown as InfoTable vs. Boolean.
