Repeater static or responsive setting
gregko
According to the Wiki (link below) there is a setting to make a repeater static or responsive.  However, I do not see the setting. How can I change it?
https://twc.thingworx.com/Thingworx/Runtime/index.html#master=ThingWorxCommunity&mashup=TWCWikiSearchResult&wiki=GeneralCommWiki40&entryID=8908
3 REPLIES 3
AdamR
(To:gregko)
This property is to set weather the mashup contained in the repeater widget is designed as a static or responsive mashup, it will not change the referenced mashup type.
Once a mashup is created there is no way to modify it from static to responsive or vice versa.
stanislav
6-Contributor
(To:AdamR)
I know this is an old topic, but I wanted to mention that I've just managed to convert a static mashup to responsive one.
I exported the xml mashup, modified the xml and imported back into the platform.
Hi Sebastian,
Yes you can do it, but there's more properties to touch apart of this one, I did it before and it caused other side effects.
Carles.
