Requires configuration of thing with Windows authentication
Muthu_chithira
7-Bedrock
Hi All,
Without DB username and DB Password, can configure a thing. Which means in SQL, Through Windows Authentication i can access DB. I Dont have any access or user credentials with SQL Server authenticaton. Is there any way to configure a THING and establish a connection between thing and DB?
Hi @Muthu_chithira.
The jdbc driver defines the access allowed and as far as I know, only SQL Server authentication is supported.  For that reason, ThingWorx does not support Windows authentication.
You may want to talk with your DBA about setting up a SQL Server account for the database you need to connect to in order to create the needed connection from ThingWorx.
--Sharon
I'd go with no, sorry.
Not sure if you have specific security rules that won't allow you to set up a DataBase Thing, but permissions and pre-built queries/views/procedures should be able to cover your scenarios.
Hi @Muthu_chithira.
--Sharon
