Responsiveness in mobile
SOLVED
I created mashup and tested it in mobile.
But it is not responsive and looks very clumsy.
In this case, Should I adjust the mashup and create a new one that fits for mobile or what will be the solution?
Please provide some help.
V Shalini.
Re: Responsiveness in mobile
What I have mostly seen is 2 mashups being used, 1 for desktop and 1 for mobile exclusively.
The biggest advantage to that is not only that you can adjust the widgets to fit smaller resolutions better, you can also add ones that make more sense on a mobile device.
Let me know if you still have any questions.
Pascal
Pascal
@svisveswaraiya-
Hope you are doing good. Could you please confirm if the issue has been resolved.
If yes, please mark the answer as accept as solution for the future reference. Thank you in advance.
Regards-Mohit Goel
