Retrieve image from database and display it on mashup
RockLala
hi Everyone
I am  trying to  stored image directly in SQL database  and then retrieve that image from table and display it on mashup. so after storing image on DB by taking image as base type of that Column and while fetching it from db by writing service it is giving me that encrypted text so my question is how i can convert it to actual images and what should be that return type of that service ? images.PNG
Thanks in advance
4 REPLIES 4
sarathi
(To:RockLala)
Hi
You can create Property in Thing  BaseType As an Image, and Update the Property with baseb4 encoded imge content  and by Using Value Display Widget  you can able view the image in Mashup Runtime
khushboo_jain
6-Contributor
(To:sarathi)
How to Update the Property with baseb4 encoded image content?
Please explain in detail.
Khushboo jain
sarathi
(To:khushboo_jain)
You can Update through custom services, or Rest API from External program,
If You  need to create Custom services
var Encodvalue ="****Image base 64 encodedValue*****";
Things["***ThingName****].**Propertyname***=Encodvalue;
Or
By Using REST API you can update  Thing Property Value....Thingworx API STRUCTURE document avalible in PTC Support Website, Please Refer That Document..
slangley
23-Emerald II
(To:sarathi)
Hi @RockLala.
If one of the previous responses helped to answer your questions, please mark the appropriate one as the Accepted Solution for the benefit of others with the same questions.
--Sharon
