I noticed in the advanced tree grid that although it returns the "Selected Rows" as an output Infotable, it does not change the selected rows from the Input Data Service. Is it the way it is supposed to work?
I explain:
I expected that the Value widged data would change as I select the different rows in the tree.
I noticed that if I bind the selected rows output from the widged to a grid it returns the infotable from that selection but I was not able to get a single value of that selection to bind to the value widget.
Any thought on this?
Ewerton
Ewerton, the value should change regardless of the widget being used, provided you bound a single data/ property from the 'Selected Row(s)' section. So, if you bound a single property from Selected Row(s) onto a Value Display widget, selecting a row should reflect whatever value the current row has.
Hi @emoreira I know its quite an old post you might already have the answer, but for the closure I wanted to share this article Service > Returned Data > Selected Row(s) is not populated when using the Tree Grid Advanced widget in Thingworx in case someone else is looking for solution. Thanks @smainente for the article
