Running another thread in the Thingworx Extension
jaeeunc
When I tried to run another thread in the Thingworx extension I'm making and tried to access an entity in the thread,
I got an error related 'permission', 'not authorized'.. something.
(for example, when writing property, 'com.thingworx.common.exceptions.InvalidRequestException: Not authorized.....'
or
ThingManager.getInstance().getEntity('mythingname') returns null )
-> Is it not permitted for the extensions to run another thread in it?
Or is there any way to get the access permission in the other thread?
3 REPLIES 3
Security permissions are tracked using ThreadLocal storage in the ThreadLocalContext class.  If you create a new thread that needs to access data from Thingworx, you will need to use ThreadLocalContext to assign it the proper security context.
Hi  Jesse,
I want to ask the a question about using ThreadLocalContext.I am trying run a thread in a function.
	public void startThread() {
		Thread t = new Thread(() -> {
			String line = "";
			try {
				SecurityContext systemContext = SecurityContext.createSystemUserContext();
				ThreadLocalContext.setSecurityContext(systemContext);
				Thing thing = ThingUtilities.findThing("AEOSEvents");
				ThreadLocalContext.clearSecurityContext();
				while ((line = reader.readLine()) != null) {
                                   thing.setPropertyValue("rawEvents", new StringPrimitive(line));
			} catch (IOException e) {
				e.printStackTrace();
			} catch (Exception e) {
		t.start();
This function gets the data coming from the socket and assing this data into thinking property.But I get the same error.Not authorized for Property Write in thingworx.I looked at the thingworx extension API Doc. But I did not find any examples about this ThreadLocalContext.Where do I make mistakes.
baobao
(To:keles0glu)
I have the same problem, the solution is to set securitycontext this code to your thread it will work.
public void messageArrived(String topic, MqttMessage message) throws Exception {
SecurityContext securityContext = SecurityContext.createSuperUserContext(); ThreadLocalContext.setSecurityContext(securityContext);
this.setPropertyValue("topic",new StringPrimitive(topic));
this.setPropertyValue("message",new StringPrimitive(message));
