Runtime exception handling data update for binding
amunozherrera
I have a particular Runtime error:
 Runtime exception handling data update for binding {"Id":"1cade67b-4d3a-4f75-bda4-72cf531d152a","SourceId":"eventsrouter-28","SourceArea":"UI","SourceSection":"","TargetArea":"UI","TargetSection":"","TargetId":"navigationfunction-24","PropertyMaps":[{"SourceProperty":"Output","SourcePropertyType":"property","SourcePropertyBaseType":"THINGNAME","TargetProperty":"idGroup","TargetPropertyType":"property","TargetPropertyBaseType":"THINGNAME"}],"isBoundToSelectedRows":false,"SourceDetails":"AllData","nEntries":1}
Exception: Cannot read properties of undefined (reading 'setParameter')
The context it's the following:
 The mashup contains a Grid and a few buttons, and labels. When clicking on one row of the grid the buttons become visible (through the use of a function). When one specific button is clicked, Popup Modal opens, we can call it Configuration Popup. While in the Popup you can either decide to navigate to another Popup or close the Configuration Popup.
If we close the Configuration Popup, upon clicking the
Hi @amunozherrera ,
You are trying to call from a Thing that is not present in the composer, due to which the issue is coming, to summarize below may be the issue
  1. Thing may be deleted
  2. The thing is misspelt in the code
Shashi Preetham,
Email: psp316r@outlook.com,
Mobile: +91 8099838001.
1 REPLY 1
Hi @amunozherrera ,
Shashi Preetham,
