SQL database connectivity issue (Thing [DatabaseController] is not running)
SOLVED
Highlighted
While trying to connect to the SQL database from thingworx . saying Thing is not running . plz check attached configuration file. actual database is at local machine and running thingworx is at another Machine .thank you
1 ACCEPTED SOLUTION
Re: SQL database connectivity issue (Thing [DatabaseController] is not running)
Hi Pai,
Thanks for reply , i tried with adding driver file to tomcat lib folder. it worked
8 REPLIES 8
Thing not running would refer to this entity itself not the database you are trying to connect to.
Try doing disable / save / enable / save see if that helps at all.
Thanks for reply , I am unable to see any option like enable or disable the thing. would you explain little more .
shared screenshot , plz check it.
thanks
yes , i got the services enablething and disablething , executed . but still having same issue
It's just the checkbox on the General tab of the Entity.
I'm assuming your Database Thing is called DatabaseController?
If after an disable save enable save it still gives the same message, then likely something got corrupted?
Hi ,
I am using Thingworx Manufacturing Apps , trial version with 3 months , i didn't get Tomcat here can i install seperately and configure it with thingworx? if yes how?? in tomcat we need to add jdbc jar file , So need it
thanks
Tomcat is installed.
the JDBC jar file, usually we install those with an extension.
Else they would go into the <thingworx>/WEB-INF folder
this might help for the jdbc.jar
https://community.ptc.com/t5/ThingWorx-Developers/Using-a-third-party-Jar-file-for-Database-connecti...
Hi Pai,
Great can you please mark this topic as solved? Thanks!
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
