Sample Question
Abhishek_Tirkey
6-Contributor
Sample Question
I am new to ThingWorx and got a sample question in the ThingWorx platform and don't know how to approach a question. Help me to understand the question and give relevant answer.
Sample Question
Note: All entities, characteristics, and fields must be spelled exactly as described
and are case-sensitive. The system will not find misspelled items.
Import the entities in W:\TWFD-CERT-Lab-Files\WGOT-ImportEntities.xml.
Examine the WGET.WashingMachine.TT Thing Template. Add the following
services and attributes:
SetRPM()
• Accepts an input parameter named rpm of type NUMBER.
• Sets the RPM property of the Washing Machine to the input parameter.
• Returns nothing.
GetRPM()
• Gets the RPM property of the Washing Machine.
• Returns the value of RPM as the result. This result is of type NUMBER.
Hint: When authoring the services, use the properties under Me/Entities to
access the RPM property.
Abhishek Tirkey
Import the W:\TWFD-CERT-Lab-Files\WGOT-ImportEntities.xml file to ThingWorx platform. That should have the WGET.WashingMachine.TT Thing Template. Post importing in composer seaarch for WGET.WashingMachine.TT. After that you can proceed with the creation of services as asked in the question.
2 REPLIES 2
Thank you @Bikash_Panda
Abhishek Tirkey
