Hi, I have a question with the Scheduler. I have to run two services at the same time and I created two subscriptions in the same Scheduler that run one service each and that have the ScheduledEvent Event as input. In what order are the services run?
If each is subscribed, you will not be able to predict which one will run first.
If you had to force the order, you can obviously run one after the other triggered in one subscription.
Not sure what requirements you have on these two services.
Thanks, paiChung. A service looks for changes in a database and updates some tables. The other service has to generate production orders for several Assets, grouped by Line. I'm going to run them in that order.
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
