Script logs
KN_9954684
Script logs
Application log and other logs are showing up in Logs section.
Script Logs are not at all showing up.Please let me know what can be the issue.
ThingWorx 9.1.0-b10877
Not sure what happend.But it's showing up now.
Thank you!!
PaiChung
22-Sapphire I
(To:KN_9954684)
First I would check the settings on your logs, what level is being logged right now and what level are you viewing.
There is a possibility that your log got so large it can't be easily processed by Thingworx.
On the server check root/ThingworxStorage/Logs and see if you see the script log there and how big it is.
I would perhaps stop tomcat, remove the logs and then restart.
Make sure you check the settings in the logging subsystem as well, those determine how large a log file it will create before 'rolling over'.
Thank you!!
