Search item in list using textbox
gajapriya
6-Contributor
I have placed textbox on top of list widget.I want to search item using text box in list widget.what serivce to write for searching items on textchanged event
1 ACCEPTED SOLUTION
I've done this with Text field widget (ptcs-textfield):
1.  I have a list with the names of the Things on the platform using Generic Thing template
2. Create new thing with a service (search_text) that is querying the things
var fieldArray = [];
var txt1=txt+"%";   //txt is the input for the service - actually what you are typing in the widget
var queryField = new Object();
var query = new Object();
if(txt1)
queryField.fieldName = "name";
queryField.type = "Like";
queryField.value = txt1;
fieldArray.push(queryField);
if( fieldArray.length > 1 )
query.filters = new Object();
query.filters.type = "AND";
query.filters.filters = fieldArray;
else
query.filters = fieldArray[0];
var params = {
maxItems: 9999 /* NUMBER */,
query: query /* QUERY */,
source: undefined /* STRING */,
tags: undefined /* TAGS */
// result: INFOTABLE dataShape: "RootEntityList"
var result = ThingTemplates["GenericThing"].QueryImplementingThings(params);
I have used 'Like' query with service QueryImplementingThings service.
3. In the mashup, create the bindings: txt from search_text bind with Text of textfield, Changed event of textfield bind with search_text service, All Data of search_text bind with  List data.
And done, when typing something in the textfield, you will get data in the list; you can adjust the query per your requirement.
* with the widget textbox , you need to hit Enter after typing to get data in the list, so I have used in above example ptcs-textfield widget.
Hope it helps,
Raluca Edu
if(txt1)
else
var params = {
Hope it helps,
Raluca Edu
slangley
23-Emerald II
(To:gajapriya)
Hi @gajapriya.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
