SearchThingsByTemplate doesn't response
drichter
I have an service which uses the SearchThingsByTemplate of SearchFunctions. In most times the service response quickly but sometime the service doesn't response or need extrem long time to response (~3 minutes).
The result includes only 13 Entities (Remote Devices). Maybe this has something todo with the isConnected-Check or so? I have no clue what I can do or where I can search for debugging.
1 ACCEPTED SOLUTION
@drichter ,
There are a couple of articles which talk about a similar issue.
Article - CS304561 QueryImplementingThingsWithData or SearchThingsByTemplate brings system to a halt...
Article - CS302119 Executing SearchThingsByTemplate service fails with "Unable to query implementing...
The articles indicate that the version of ThingWorx affects the response. Can you provide the version you are using? I will let you know if I find any other information.
Thanks.
Peter
@drichter ,
Thanks.
Peter
slangley
23-Emerald II
(To:drichter)
Hi @drichter.
If you are satisfied with the previous response, please mark it as the Accepted Solution for the benefit of others on the community.
Regards.
--Sharon
