Security context stack is growing large
tcoufal
Hi Guys,
I have quite large problem. It is few days ago when this warning start to showing up in my Application log. It is very fast filling my Application log files.
I can see that the problem is coming from WebSocket subsystem, but I cannot find from where exactly.
We are using Kepserver + IoT gateway with Websocket agents.
But it worked without problems few months until know.
Is there anyway how to trace the source?
Tomas
tcoufal
(To:ankigupta)
Found the problem.
I was heaving few subscriptions of DataChangeEvent and one was set on Property that I was changing in the same script. So it was stuck in a loop.
Stupid..
Luckily I was not the one who made that mistake , but it was more difficult to find.
Tomas
8 REPLIES 8
posipova
20-Turquoise
(To:tcoufal)
Do you have a connections server? Is there any other errors in the application log? What is your thingworx version?
tcoufal
(To:posipova)
We are not using a connection server. Version is 7.2.0.
There is only one (two) other errors in AppLog
ankigupta
(To:tcoufal)
Are the errors messages consistent with the warning messages? From the error message it seems that service is being invoked with some null data.
tcoufal
(To:ankigupta)
No consistency that I can find.
I would need to know what that Message is in a first place.
What does it mean?
tcoufal
(To:ankigupta)
This is the error which I think is of some importance, however I dont where the problem could be.
error executing APIRequest Message: Unable to dispatch [ uri = /Things/CBF6/Services/UpdateSubscribedPropertyValues/]: Unable to Invoke Service UpdateSubscribedPropertyValues on CBF6 : null, sending ERROR ResponseMessage to caller!
tcoufal
(To:ankigupta)
Found the problem.
Stupid..
Tomas
qngo
(To:tcoufal)
With a fresh install of TWX Postgre 7.4 (after running script DBCleanup, DBSetup, SchemaSetup), I imported some extension like Mail, Autocomplete, Logout Button.... Then, with user Administrator, create and delete Things (GenericThing) generate these warnings !
Abhiram
(To:tcoufal)
Hi Tomas,
We have a condition to terminate loop, so it should execute right, but why still it give that error?
