Segmentation Fault in C SDK when getting property data from Thingworx
SS_10329829
Hello community,
I define "data0" as number of remote property in Thingworx. In C SDK, I try to get the value in "data0" using tempPrimitive->val.number. However, there is segmentation fault in the command of "tempPrimitive->val.number"
twPrimitive *tempPrimitive = 0;
twApi_ReadProperty(TW_THING, thingName"data0", &tempPrimitive, 1000FALSE);
printf("%lf",tempPrimitive->val.number);
May I know how to solve the segementation fault issue?
Is it related to binary file and library mismatched? If yes, may I know how can I solve mismatched issue?
Thank you.
slangley
(To:SS_10329829)
Hi @SS_10329829.
What version of the c-SDK are you running?  Can you send the full code so we have a better idea around the library you're using?
--Sharon
