Select multiple values from combo box and assign to a service
sanil
I have a combo box with multiple values that will be selected in it.How can i assign this vaues to a service with input as infotable or aything.Basically i want to know whihc all values got selected in the combo box as of now am getting only 1 value instead of all selected values
To enable multi-select on combobox widget (List Widget) you need to enable MultiSelect option first, then once done it, on the right side of Mashup Builder you just need to bind the "Selected Rows(s)" as a whole to the Service that will ingest the selected rows.
