How can I use the selected item from a list widget (I've modified it to a drop down) to output as an input to a different service?
Hi Michael,
To use the selected item from a List widget, bind the Selected Row(s) from the Service used to populate the List. You can use the entire info table or a specific field (by expanding Selected Row(s)) as an input to another Service.
Adam
Worked out perfect! Thanks for the help Adam.
