I have a list of entities prepared in an infotable. Looks like "Things[entityname].SetTags(params);" this code works only for things but not for media and style definition entities. Please help.
try
var selectedTags = INFOTABLE; \\(list of entities);
var tableLength = selectedTags.rows.length;
for (var x = 0; x < tableLength; x++) {
var row = selectedTags.rows[x];
var tags = new Array();
var params = {
tags: "TagName:Voc"
var entityname = row.name;
catch(err) {
logger.error("Error @ Thing -"+me.name+", Myservice, @ line " + err.lineNumber + ": " + err);
Hello @DM_9985019 ,
I personally haven't tried this, but for Media entity and Style Definition, can you please below two:
MediaEntities[entityname].SetTags(params);
and
StyleDefinitions[entityname].SetTags(params);
Shirish
Media entities most likely (I haven't tried) do not support services, so to get tags on a Media entity, you probably need to rewrite the full definition.
I don't recall there to be a specific service to just add tags to a Media entity.
Hello @DM_9985019 ,
and
Shirish
Hi @DM_9985019.
If either of the previous responses allowed you to find a solution, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
