Set Things password from service
gabitudor
i have many Things with "Database" as Thing Template and i would like to make a service which sets the password to the database automatically (on running the service).
i looked into the snippets and found nothing so i thought it might be a security policy.
is it possible? Thanks :)
Configuration section of a thing it's based on Configuration Tables, you should look on the services related to Configuration Tables in order to change any property shown on that section. Let's start:
  • GetConfigurationTables -->
    • ColumnAliases
    • ConnectionInfo
    • ConnectionMonitoring
  • From previous service we can infer that password will be on ConnectionInfo
  • GetConfigurationTable({ tableName: "ConnectionInfo"}) -> Infotable with the following columns
    • jDBCDriverClass, jDBCConnectionURL, connectionValidationString, MaxConnections, userName, password
  • Here we have the password value (but it's shown as ****), if you do it from a service you will see the real password (at least for TW 7.3.X )
  • Now you only need to Set the previous Configuration Table. the corresponding SetConfigurationTable or SetConfigurationTableRows in order to update the password accordingly.
Carles.
    • ColumnAliases
    • ConnectionInfo
Carles.
Hi Charles,
thanks for the answer! I tried as you said but i am facing a problem.
// result: INFOTABLE dataShape: "EntityList"
var result = me.GetConfigurationTables();
// table: INFOTABLE dataShape: ""
var table = me.GetConfigurationTable({
tableName: "ConnectionInfo" /* STRING */
me.SetConfigurationTableRows({
values: undefined /* INFOTABLE */,
persistent: undefined /* BOOLEAN */,
tableName: undefined /* STRING */
Here, at SetConfigurationTableRows, what am i supposed to fill? i cannot see the connection to the password i would like to change. Thank you!
Something like this should do the trick:
var newPassword ="newDesiredPassword";
var databaseName = "yourDataBaseName";
var tableName = "ConnectionInfo";
var actual = Things["PersistenceProviderSystemDatabase"].GetConfigurationTable({ tableName: tableName });
actual.rows[0].password = Resources["EncryptionServices"].EncryptPropertyValue({ data: newPassword });
Things[databaseName].SetConfigurationTable({
    configurationTable: tableName,
    persistent: true,
slangley
(To:CarlesColl)
Hi @gabitudor.
If one of the responses provided by @CarlesColl answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
