I am trying to set focus back to a Textbox after a service runs in a modal popup. Tab sequence is set to 1, so it does put cursor in the Textbox when the mashup is loaded, but not after a service is run. I have tried several things to no avail.
Any suggestions would be much appreciated.
Hi @msundstedt.
You would need to create a custom widget that would expose the Focus function as a bindable event.
--Sharon
Hi @msundstedt.
--Sharon
Hi @msundstedt.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
