Set focus to a Textbox after a service runs in a modal popup
msundstedt
2-Explorer
I am trying to set focus back to a Textbox after a service runs in a modal popup.  Tab sequence is set to 1, so it does put cursor in the Textbox when the mashup is loaded, but not after a service is run.  I have tried several things to no avail.
Any suggestions would be much appreciated.
slangley
(To:msundstedt)
Hi @msundstedt.
You would need to create a custom widget that would expose the Focus function as a bindable event.
Regards.
--Sharon
slangley
(To:msundstedt)
Hi @msundstedt.
Regards.
--Sharon
slangley
(To:slangley)
Hi @msundstedt.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
