Setting a location field in an infotable
fblondy
7-Bedrock
Hello there !
I've got a little problem here, I'm trying to get some network connections with the location field of the Things added in, but when I do this :
for (var x = 0; x < tableLength; x++) {
    var row = result.rows;
    row.location = Things[row.to].geolocalisation;
I only get some NaN in the field;
I can still retrieve the field correctly when I add it in a new row (i'll probably just do this but I still wanted to ask).
Thanks for reading
4 REPLIES 4
billrei
(To:fblondy)
There are a few ways this snippet could fail.
1. Are tableLength and result.rows the same length?
2. Is row.to a valid ThingName that exists?
You should add some logger.info(""); lines and look in your scripting log in Monitoring>Script to make sure these values are valid. NaN stands for Not A Number which is usually the result of an impossible calculation. Variables that fail to get assigned would would have the value, "undefined". Can you post the entire service?
fblondy
7-Bedrock
(To:billrei)
Yeah, everything is looking good until i'm trying to put the location value in the location field
as you'll see, row.to is a valid thingName since i'm getting it directly from the network  and the length are effectively one and the same
and the geolocalisation field is a valid and legit one
Here's the whole service (new working version) :
var params = {
    maxDepth: depth /* NUMBER */,
    start: start /* STRING */
var nw = start ? Networks[network].GetSubNetworkConnectionsWithTemplate(params) : Networks[network].GetNetworkConnectionsWithTemplate(params);
var params = {
    infoTableName : "InfoTable",
    dataShapeName : "NetworkConnectionWithData"
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var tableLength = nw.rows.length;
    var row = nw.rows;
    var newEntry = new Object();
    newEntry.from = row.from; // STRING - isPrimaryKey = true
    // row.location =  Things[row.to].geolocalisation <-- This is what doesn't work
    newEntry.location = Things[row.to].geolocalisation; // LOCATION
    newEntry.avatar = Things[row.to].GetAvatarURL(); // IMAGELINK
    newEntry.thingTemplate = Things[row.to].thingTemplate; // THINGTEMPLATENAME
    newEntry.to = row.to; // STRING - isPrimaryKey = true
    newEntry.connectionType = row.connectionType; // STRING
    var dN = Things[row.to].displayName;
    newEntry.display = dN ? dN : row.to;
    newEntry.alert = Things[row.to].alert ? Things[row.to].alert : false;
    result.AddRow(newEntry);
paic
(To:fblondy)
Do you get a proper location when you do a logger.warn on your Things[row.to].geolocalisation?
billrei
(To:fblondy)
I suspect that what you are getting back from GetSubNetworkConnectionsWithTemplate() is an InfoTable of Java objects of Connection class. This would make the returned rows read only. I suggest that you build a new object and copy everything you want from the returned Connection classes like you are currently doing.
