Setting the Environment Variable Azure IoT Hub
Alex23
I am trying to connect Azure IoT Hub to thingworx and I am facing a problem when I need to set the environment variable. When I run this line into the shell :
set AZURE_IOT_OPTS=-Dconfig.file=C:\Thingworx-Azure-IoT-Hub-Connector-2.0.0.141\connector\conf\azuire-iot.conf
-Dlogback.configurationFile=C:\Thingworx-Azure-IoT-Hub-Connector-2.0.0.141\connector\conf\logback
I have an error :
 -Dlogback : The term «-Dlogback » is not recognized as a cmdlet, function, operable program, or script file.
Thanks.
cdovholuk
(To:Alex23)
you have added too many quote. just 2 are needed:
set AZURE_IOT_OPTS=-Dconfig.file="C:\Thingworx-Azure-IoT-Hub-Connector-2.0.0.141\connector\conf\azuire-iot.conf -Dlogback.configurationFile=C:\Thingworx-Azure-IoT-Hub-Connector-2.0.0.141\connector\conf\logback"
5 REPLIES 5
cdovholuk
(To:Alex23)
if there's spaces you need to properly 'quote' the line:
set AZURE_IOT_OPTS="-Dconfig.file=C:\Thingworx-Azure-IoT-Hub-Connector-2.0.0.141\connector\conf\azuire-iot.conf
Pretty sure that will fix it
Alex23
(To:cdovholuk)
Thank you but now I have another error, in fact when I run
set AZURE_IOT_OPTS=-Dconfig.file=C:\Thingworx-Azure-IoT-Hub-Connector-2.0.0.141\connector\conf\azuire-iot.conf -Dlogback.configurationFile=C:\Thingworx-Azure-IoT-Hub-Connector-2.0.0.141\connector\conf\logback
with a single space between azure-iot.conf and -Dlogback I have this error:
Set-Variable : A parameter cannot be found that matches parameter name "Dlogback".
cdovholuk
(To:Alex23)
The response you posted doesn't seem to be properly quoted yet. Did you add a quote after the equals sign and at the end of the line
Alex23
(To:cdovholuk)
I followed the example given by PTC Support here
When I add quote as
set AZURE_IOT_OPTS=-Dconfig.file="C:\Thingworx-Azure-IoT-Hub-Connector-2.0.0.141\connector\conf\azuire-iot.conf" -Dlogback.configurationFile="C:\Thingworx-Azure-IoT-Hub-Connector-2.0.0.141\connector\conf\logback"
I still have the same error....
I am working on Windows 10 (x64) machine.
cdovholuk
(To:Alex23)
