Hello everyone,
I would like to have one Mashup Page which contains a Tree Widget. The Tree Widget contains my Things of interest in some hierachical order. I would like to show the Home Mashup of Each Thing in a contained Mashup widget when clicked on the Thing in the Tree.
What is the way to go to achieve this?
Means: What exactly does the main Infotable contain?
Best Regards,
Dominik
Since you want a Tree list of Things of interests, so you need to create you own list in the Datatable.
The Datashape should contain: 1. Thing Name 2. Parent ID 3. own ID 4. HomeMashup
you need to manually fill in the value for first 3 columns, and for column 4 you can use
var HomeMashup = me.GetHomeMashup(); in the addDatatableEntry service.
hello @zyuan1 ,
thank you for your reply.
Can you also tell how I could display the avatars of each thing in the tree?
Also I would like to have none-Thing Nodes in the Tree which simply represent Groups of Things. Should I just write an entry in the data table and leave the home mashup blank?
var Avatar = me.GetAvatar();
For non-Thing nodes, yes you can, and don't include them in your customized service which automatically add the Home mashup, use the system service addDatatableEntry directly
Alright,
but I dont see a field in the tree widget where I could bind the avatar property
