Is there a way to slow down the input of the Events Router function? I'm trying to use an events router function, but the first input will always be the latest because it is refreshed every time the page loads. The thing is, I want the second input to evaluate as true whenever a menu item is not being selected, which will be most of the time.
Not too sure what logic you are applying, but since you can't slow things down, I think you have to look at doing the logic differently.
Hi Ike@ACE.
Were you able to come up with a solution to your problem? If so, we would be happy for you to share with the community.
--Sharon
