Some Data Tables created through Service are not displaying.
magrawal
2-Explorer
Hello Carles Coll,
I have written a service to create Data Tables dynamically. Service is working fine. Some Data tables created through service are in list of data tables but some are not in list.
I am not getting the reason and where could I see those data tables.
Thanks in advance,
Meenakshi
Various things can happen...
  • Visibility --> If you are on Administrator user should not, but otherwise can be a visibility problem ( organizations / visibility )
  • Transactional Problems --> If some of your DataTable creator scripts fail for some reason and throws and uncached exception then you will have a transaction rollback, which can take in effect after a tomcat restart <-- I think that can be your case
Carles.
6 REPLIES 6
Carles.
1) I am an Administrator use.
2) I have restarted tomcat and still data tables are not visible.
Data Tables are created but not in list as I am trying to create dt with the same name it is throwing "entity already exist" exception. So it is cnfirmed that Data tables are created.
2) --> Yes That's what I mean, if you have an unfinished transaction ( becouse of a exception thrown) on tomcat restart DataTables will be rolledback --> DataTables removed .
You should not let throw "Entity already exist" exception on the wild --> I think this is the problem, check first if Entity Exist before trying to recreate it, you can easily do it like:
var myDataTable= Things["myDataTableName"];
if (myDataTable==null) {
   // -- you can "safely" create the datatable.
Hey Carles Coll
I tried it but still facing the same issue.
where can I find that created data tables as they exist but not in list?
Is there a way so that I can delete them?
Please help.
Meenakshi
If you created ghost entities, you have a tool to remove them on the marketplace: http://marketplace.thingworx.com/Items/Ghost%20Entities%20Cleaner
Thank you so much Carles Coll
my problem got solved.
