I see that some data table things I create doesn't have the Mashup option to view the content of it. Surprisingly, few data table things get that option. Am I doing any mistake while creating the Data Table (I am using the same Data Table Thing Template as Base thing template while creating the data tables and that Thing Template also has the DatatableEditor as its Home Mashup) ?
Licensed ThingWorx version: 8.3.3
Hello All,
I found out the solution for the issue I posted. Though the Data Table Base Thing Template had the DataTableEditor as the Home Mashup , for some reasons the home Mashup for the Thing was not set to DataTableEditor ( it was empty). Upon manually choosing the DataTableEditor as the home Mashup for the Data Table Thing, the problem was solved :)
Hello All,
