Hi there!
I have a main mashup with a tab widget and a mashup container inside the second tab. This mashup container calls a mashup that contains a menu widget.
What happens is: I cannot see the menu widget in the main mashup unless:
I don't want either of these options. What am I missing?
This is what I should get:
This is what I am getting:
Thanks in advance.
Best regards.
Hello, Irene.
Can you export that mashup and upload it for us to take a look at?
Also, what version of ThingWorx are you running?
Thank you,
-- Craig A.
Hi Craig,
Thanks for coming back to me. I guess you want me to put the url, don't you? I have just realized that I cannot access the mashup from other machines...
I am running version 7.4.
Thanks.
Best regards.
Hi Irene.
That might work; I was suggesting exporting the mashup to a files and attaching it so we could import it and see what's happening.
-- Craig A.
Hi Craig,
Please, find attached the mashup and the menu. This is the url, but I cannot access the page: http://192.168.51.12:5353/Thingworx/Runtime/index.html#master=MACMaster&mashup=MainMashup2
Thanks.
Best regards.
Irene
Are you in chrome? If you click f12, you may look into the dev tools. Try navigating/hovering over the area where the disappeared tabs are and see if there is anything unusual with the styling.
Hi Polina,
I did that but I did't understand what the problem was exactly. Could be something wrong in the definition style?
Thanks.
Hi Polina,
Did you find anything in the mashups?
Thanks.
Best regards.
