Sort column with "GRID ADVANCED extension" not working ?
pjoly
11-Garnet
hello
I'm using the new extension "grid advanced" in release 1.1.1 with a getImplementingThingsWithData service
I'm using Thingworx 7.3.2-b42
The widget works fine except for sortinG.
I have activated the sort option into the widget.
I can see the small triangle to sort a column but the grid is not refresh when using it.
Is there something to bind or to do to have it working ?
posipova
20-Turquoise
(To:pjoly)
There should be example entities  that are included in the package - please see the bindings. The sort feature needs a query to perform the sort.
6 REPLIES 6
posipova
20-Turquoise
(To:pjoly)
Let me investigate/reproduce and I will get back to you with results.
pjoly
11-Garnet
(To:posipova)
Hello
I noticed also than the "auto-width" option for column is not working with this new grid widget.
posipova
20-Turquoise
(To:pjoly)
Also a quick note, the advanced grid widget is to be used with Thingworx version 7.4 or later.
pjoly
11-Garnet
(To:posipova)
you should correct the market place if not compatible < 7.4
Release Date:March 31, 2017
Last Updated:March 31, 2017
Current Version:1.1.1
Software Application Type:Extension
Requirements:ThingWorx 7.2+
posipova
20-Turquoise
(To:pjoly)
pjoly
11-Garnet
(To:posipova)
Hello
I bound the queryfilter to my QueryImplementingThingWithData query + filter action on this service and it works
