hello
I'm using the new extension "grid advanced" in release 1.1.1 with a getImplementingThingsWithData service
I'm using Thingworx 7.3.2-b42
The widget works fine except for sortinG.
I have activated the sort option into the widget.
I can see the small triangle to sort a column but the grid is not refresh when using it.
Is there something to bind or to do to have it working ?
There should be example entities that are included in the package - please see the bindings. The sort feature needs a query to perform the sort.
Let me investigate/reproduce and I will get back to you with results.
Hello
I noticed also than the "auto-width" option for column is not working with this new grid widget.
Also a quick note, the advanced grid widget is to be used with Thingworx version 7.4 or later.
you should correct the market place if not compatible < 7.4
Release Date: | March 31, 2017 |
Last Updated: | March 31, 2017 |
Current Version: | 1.1.1 |
Software Application Type: | Extension |
Requirements: | ThingWorx 7.2+ |
Regards
Hello
I bound the queryfilter to my QueryImplementingThingWithData query + filter action on this service and it works
