I am trying to sort an infotable result set based on specific order (array)
Example:
My Infotable result set:
| Column1 | Column2 | Column3 |
| d | desc1 | desc one |
| h | desc2 | desc two |
| f | desc3 | desc three |
| t | desc4 | desc four |
My order to sort :: [f,t,h,d]
Expected result set after sorting
Would highly appreciate a quick turnaround.
Thanks in advance.
Not super efficient, but should work:
function sort(array,sortOrder,sortColumn) {
function sortFunc(a, b) {
return sortOrder.indexOf(a[sortColumn]) - sortOrder.indexOf(b[sortColumn]);
var temp = [];
for each(row in array.rows) temp.push(row);
var nItems = array.rows.length;
for (var i=0;i<nItems;i++) delete array.rows[0];
temp.sort(sortFunc);
for (var i=0;i<temp.length;i++) array.AddRow(temp[i]);
sort(result,['f','t','h','d'],'column1');
var temp = [];
Thanks Carles it worked :)
Hi @CarlesColl
I have one more additional requirement for info table sorting.
My sort array may not have all the values in the specified column. Only specified values of column must be sorted at beginning and remaining as per existing order.
Example:
Example:
My order to sort :: [f,t]
Thanks in advance.
You have the clues on my previous post, just analyse it and adapt to your use case ;)
