I am using state based formatting i.e.
if X<40 state = low
if X<80 state = medium
if X<100 state = high
Though I'd like to add an additional condition, such as...
if Y = true state = unavailable
Is it possible to do this with scripting?
The end goal:
I have a gauge that displays as red orange or green (depending on variable X), as shown below. However, if the "isConnected" variable (i.e. variable Y) switches to false, I would like the gauge to display a different colour, such as grey, for example.
Thanks!
You can put two gauges on over the other, and show/hide one or the other depending on Y
Thanks, this works.
