State Definition Minimum Value
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Is there any way that you can set the state definitions so that you don't have to hard code the minimum value, it would be nice if it could be passed in from your dataset as sometimes the minimum is calculated or changes from data to data.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Generally speaking when you apply a state definition, the state definition cut offs or value matches are exposed as bindable properties on the widget. So yes you can dynamically set the value.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I see where the value compare is bindable but I don't see where you can configure the cut off value. It allows me to modify it but not bind it when I click on the statedefinition attached to the gauge (that's what I am currently working on using). Can you explain what piece I am missing?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
From another Widget or Service you can take a value and bind that to the Cut-off that is exposed as a property.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
perfect, thanks I see it now, it is called ValueFormatter_(what ever the description you defined is)
