We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
Hi there,
I've been installing ThingworxTrial and faced a strange error for which I could not find any resource.
Config & install steps: Window10 64bits, 2 CPUs-10GB of ram & 50 GB of storage allocated to on docker, DockerMachinePTC is the only VM, Hyper-V enabled, VirtualBox DHCP IP range set, no other app uses port 8080.
The error message, install.log, ThingWorx Industrial Connectivity 8.log, Thingworx Industrial Connectivity-install.log are attached.
Setting variable thingworx_industrial_connectivity_appkey from cmd /c "C:\Program Files (x86)\ThingWorxTrialEdition\default\configure_appkey.exe" "-hostname=10.0.75.1" "-hostport=8080" "-username=Administrator" "-password=trUf6yuz2?_Gub" "-appKeyName=IndustrialConnectivityInstallerKey"
Script exit code: 0
Script output:
02725c8c-d22b-4392-9022-257173d08a76
Script stderr:
Installing ThingWorx Industrial Connectivity ...
Executing .\ThingworxIndustrialConnectivity-8.2.64-windows-installer.exe --installdir "C:\Program Files (x86)\ThingWorxTrialEdition" --install_report "thingworx_industrial_connectivity_report.json" --twxHostName "10.0.75.1" --twxHostPort "8080" --twxAppKey "02725c8c-d22b-4392-9022-257173d08a76" --unattendedmodeui minimal --mode unattended --accept_eula YES
Script exit code: 1
Script output:
There has been an error.
Failed to execute installation action for Thingworx Industrial Connectivity
Script stderr:
Program ended with an error exit code
Error running .\ThingworxIndustrialConnectivity-8.2.64-windows-installer.exe --installdir "C:\Program Files (x86)\ThingWorxTrialEdition" --install_report "thingworx_industrial_connectivity_report.json" --twxHostName "10.0.75.1" --twxHostPort "8080" --twxAppKey "02725c8c-d22b-4392-9022-257173d08a76" --unattendedmodeui minimal --mode unattended --accept_eula YES: Program ended with an error exit code
Problem running post-install step. Installation may not complete correctly
[16:44:32] - Rolling back installation: docker_label = TWX...
Thank you for your post. Are you seeing this error when running ThingWorxIndustrialConnectivity.exe version 6.5.829.0?
Rob
