RE: https://developer.thingworx.com/resources/guides/google-map-widget-how#
Display Geolocation Data in Your UI > Overview > Configure Google Maps Widget Extension >
at Step 6, my import fails with following error:
Validation Results
Not Acceptable
Is my googlemap widget entry in my metadata.xml file correct? Instructions are not so clear to me..
I just ran through the directions and was able to import the widget after adding my own app key.
I was able to duplicate the error message "Not Acceptable" by re-zipping the extension from the top level directory which adds an extra level in the path to the widget. Confirm that the zip file you created does not add another directory level
