Style theme for dropdown in thingworx 9.0 not working
mervinnobelraj
I Have Created the two style theme for dropdown widget. In the dropdown list the color theme is applying, but I was unable to change dropdown style in the style theme.
Kindly Let me know what are the steps next to do.
Thanks & Regards,
Mervin
Hi @mervinnobelraj, I guess you have already bound the output of the dropdown to dynamically change the color of the background (by changing the theme style)
In order to change the style of dropdown itself, you can change the settings from Styles > Elements > Grids and Lists > Lists and Dropdowns.
Hi @CharlesJi ,
I am not able to change background of the dropdown, but I was able to change the list background.
Hi @mervinnobelraj, if it is not there, you may try with the CustomCSS.
