Subscription is not updating value to Things Using Thingworx Composer.
I have configured Template and Things. Set Alert and Subscription using JS. But, it is not updating values to Things Properties. Please help me.
Subscription Code:
me.LastAlertLocation = 'East Weather Station'
me.Destination = 'Dust Storm'
Is the alert getting generated on which you had written the subscription code ? You can check from Monitoring Tab if alert is getting generated or not.
Hi @mksmrityunjay.
Have you been able to resolve your issue? If so, please post your solution here for the benefit of others in the community.
--Sharon
Hi @mksmrityunjay.
Please let us know if you have resolved your issue. If one of the previous posts allowed you to find a solution, please mark the appropriate one as the Accepted Solution for the benefit of others on the community.
--Sharon
Hello @mksmrityunjay,
Make sure you enabled the subscription (they are disabled by default).
/ Constantine
