Sudden need for FooterData in Grids
Ike@ACE
Has anyone else had a sudden problem where they are unable to use Advanced Grids because the FooterData property is acting up? We've been using these Grids for a few months now. Not only has there never been a problem, I've never had a to-do list item for a lack of FooterData. I did a quick search and found that I should just need to uncheck the box for the EnableFooter property. Unfortunately, I can't even find that. Does anyone have any suggestions?
Hi Ike@ACE ,
I am using 9.1 Version, and if you check the properties it is available.
Attaching a screenshot for your reference.
And if you are using some other version, kindly revert back.
Ike@ACE
(To:bchaudhary)
Unfortunately, I'm on 8.5
Hi Ike@ACE
footer in advance grid
Can you please check the given link?
It is available in 8.5 too.
Kindly revert back if you are still facing the challenge.
Bhawna
Ike@ACE
(To:bchaudhary)
There is actually no longer a problem for some unknown reason. We're not sure what caused it, but everything is fine now
Ike@ACE ,
Good to hear that.
