Hi ,
We could see the below answer in the community , is still TimeScaleDB is not supported ? could you please confirm
TimeScaleDB as Persistent Provider
Hi @AA_11253682 As per the latest help center TimeScaleDB is currently not supported.
Hi @AA_11253682 Do you still require help on it then let us know otherwise mark it as the accepted solution.
Hi Surya ,
Also could you please share the version detail of influxDB which currently supporting with thingworx ?
Anna
It depends on the ThingWorx version. Please refer to the Release Advisor for exact compatibility matrix.
Hi Surya ,
Please guide me which option need to check for influxdb veriosn ?
Hi Surya ,
We would need to know thw supported verion of influxdb not thingworx one .
Please share the latest version of influxdb which supports thingworx .
Anna
Hi @AA_11253682 We have provided support to influx DB, look at the attachment.
Hi @AA_11253682,
It appears that this response may answers your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Abhi
Hi
Thanks for your response and support ,
Can you please confirm , any plan to support timescaledb in near future ?
Anna
